Saltar al contenido principal
Azpen A701 Battery Replacement
Qué necesitas
  1. Azpen A701 Battery Replacement, General Disassembly Prerequisite Guide: paso 1, imagen 1 de 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Battery Replacement: paso 2, imagen 1 de 2 Azpen A701 Battery Replacement: paso 2, imagen 2 de 2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Battery Replacement: paso 3, imagen 1 de 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Battery Replacement: paso 4, imagen 1 de 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Remove red and black wires leading from the battery to the motherboard by heating up a soldering iron and applying to area and gently removing wires.
    • For more information on soldering, please refer to iFixit's guide here.
  6. Azpen A701 Battery Replacement: paso 6, imagen 1 de 1
    • Insert new battery by soldering red and black wires onto the motherboard.
    • Make sure to solder the wires back on in the correct configuration (as pictured).
Conclusión
Grant Harding
Miembro Desde 03/11/15
249 Reputación
2 Guías creadas
Equipo
Colorado Springs, Team 2-1, Panko Spring 2015 Miembro de Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
Miembros de 3
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 10
Todo El Tiempo: 748
