Saltar al contenido principal
Axess TA2513-10WT Speaker Replacement
Qué necesitas
  1. Axess TA2513-10WT Speaker Replacement, Back Cover: paso 1, imagen 1 de 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Speaker Replacement: paso 2, imagen 1 de 3 Axess TA2513-10WT Speaker Replacement: paso 2, imagen 2 de 3 Axess TA2513-10WT Speaker Replacement: paso 2, imagen 3 de 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Speaker Replacement: paso 3, imagen 1 de 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Speaker Replacement: paso 4, imagen 1 de 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Speaker Replacement, Speaker: paso 5, imagen 1 de 1
    • Remove tape attached to black and red speaker wires.
  6. Axess TA2513-10WT Speaker Replacement: paso 6, imagen 1 de 1
    • Identify the four speaker nodes.
    • From left to right the nodes are "SPKP1", "SPKN1", "LN", and "LP"
  7. Axess TA2513-10WT Speaker Replacement: paso 7, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Place the soldering tool on the speaker node labeled "SPKP1" and quickly remove the red wire with tweezers.
  8. Axess TA2513-10WT Speaker Replacement: paso 8, imagen 1 de 1
    • Place the soldering tool on the speaker node labeled "SPKN1" and quickly remove the black wire with tweezers.
  9. Axess TA2513-10WT Speaker Replacement: paso 9, imagen 1 de 1
    • Place the soldering tool on the speaker node labeled "LP" and quickly remove the black wire with the tweezers.
  10. Axess TA2513-10WT Speaker Replacement: paso 10, imagen 1 de 1
    • Place the soldering tool on the speaker node labeled "LN" and quickly remove the red wire with tweezers.
Conclusión
Steven Kavanagh
Miembro Desde 03/24/15
301 Reputación
3 Guías creadas
Equipo
Baylor, Team 6-3, Shaver Spring 2015 Miembro de Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 323
