Saltar al contenido principal
Axess TA2513-10WT Side Button Replacement
Qué necesitas
  1. Axess TA2513-10WT Side Button Replacement, Back Cover: paso 1, imagen 1 de 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Side Button Replacement: paso 2, imagen 1 de 3 Axess TA2513-10WT Side Button Replacement: paso 2, imagen 2 de 3 Axess TA2513-10WT Side Button Replacement: paso 2, imagen 3 de 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Side Button Replacement: paso 3, imagen 1 de 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Side Button Replacement: paso 4, imagen 1 de 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Side Button Replacement, Buttons: paso 5, imagen 1 de 2 Axess TA2513-10WT Side Button Replacement, Buttons: paso 5, imagen 2 de 2
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  6. Axess TA2513-10WT Side Button Replacement: paso 6, imagen 1 de 2 Axess TA2513-10WT Side Button Replacement: paso 6, imagen 2 de 2
    • Unlatch the clear rubber holder from the posts with the tweezers.
  7. Axess TA2513-10WT Side Button Replacement: paso 7, imagen 1 de 2 Axess TA2513-10WT Side Button Replacement: paso 7, imagen 2 de 2
    • With tweezers, pull the rubber holder from the back cover completely.
  8. Axess TA2513-10WT Side Button Replacement: paso 8, imagen 1 de 3 Axess TA2513-10WT Side Button Replacement: paso 8, imagen 2 de 3 Axess TA2513-10WT Side Button Replacement: paso 8, imagen 3 de 3
    • Remove the individual buttons with tweezers.
Conclusión
Lori Scott
Miembro Desde 03/24/15
101 Reputación
1 Guía escrita
Equipo
Baylor, Team 6-3, Shaver Spring 2015 Miembro de Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 221
