Saltar al contenido principal
Axess TA2513-10WT Back Cover Replacement
Qué necesitas
  1. Axess TA2513-10WT Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Back Cover Replacement: paso 2, imagen 1 de 3 Axess TA2513-10WT Back Cover Replacement: paso 2, imagen 2 de 3 Axess TA2513-10WT Back Cover Replacement: paso 2, imagen 3 de 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Back Cover Replacement: paso 3, imagen 1 de 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Back Cover Replacement: paso 4, imagen 1 de 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
Conclusión
Una persona más ha completado esta guía.
Hayley Rabe
Miembro Desde 03/24/15
125 Reputación
1 Guía escrita
Equipo
Baylor, Team 6-3, Shaver Spring 2015 Miembro de Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 256
