Saltar al contenido principal
Axess SPBT1031 Speaker (Horns) Replacement
Qué necesitas
  1. Axess SPBT1031 Speaker (Horns) Replacement, Black Faceplate: paso 1, imagen 1 de 1
    • Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
    • Both screws are 0.55 cm in depth
  2. Axess SPBT1031 Speaker (Horns) Replacement: paso 2, imagen 1 de 1
    • Separate the black face plate from the tube by pulling them apart.
    • Be careful when pulling the wires apart or it will potentially damage the wires due to over stretching.
  3. Axess SPBT1031 Speaker (Horns) Replacement, Speaker (Horns): paso 3, imagen 1 de 1
    • By this point you should have determined which speaker needs to be replaced, to figure this out please refer back to the troubleshooting guide.
    • For the top horn replacement, you will be working with the blue and white wire pair.
    • For the bottom horn replacement you with the yellow and white wire pair.
  4. Axess SPBT1031 Speaker (Horns) Replacement: paso 4, imagen 1 de 2 Axess SPBT1031 Speaker (Horns) Replacement: paso 4, imagen 2 de 2
    • To remove the plastic coating around the desired horn, look on the back of the black face plate you removed and use the philips head ph1 screwdriver fitting to remove the two 0.3 cm Philips Head screw and washer combos on the left and right of the horn.
    • Screw depth of 0.7 cm
  5. Axess SPBT1031 Speaker (Horns) Replacement: paso 5, imagen 1 de 1
    • Lift the horn from its fitting by pulling it. Position it in a manner that is easy to work with.
  6. Axess SPBT1031 Speaker (Horns) Replacement: paso 6, imagen 1 de 2 Axess SPBT1031 Speaker (Horns) Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Desoldering Pump
    $3.99
    Comprar
    • Use a soldering iron to heat the two contact points.
    • Then use a desoldering pump to remove the liquid solder.
  7. Axess SPBT1031 Speaker (Horns) Replacement: paso 7, imagen 1 de 1
    • Remove the wires--blue or yellow wire depending on the horn you are replacing--from the old speaker and remove the speaker from the fitting location.
    • For the bottom horn replacement, you will be working with the yellow and white wire pair.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 18
Todo El Tiempo: 1,837
