Saltar al contenido principal
Axess SPBT1031 Battery Replacement
Qué necesitas
  1. Axess SPBT1031 Battery Replacement, Red Interface Plate: paso 1, imagen 1 de 1
    • Use a metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
  2. Axess SPBT1031 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the four 5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
  3. Axess SPBT1031 Battery Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
  4. Axess SPBT1031 Battery Replacement: paso 4, imagen 1 de 1
    • Separate the red interface plate from the black face plate by pulling them apart.
  5. Axess SPBT1031 Battery Replacement, Black Faceplate: paso 5, imagen 1 de 1
    • Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
    • Both screws are 0.55 cm in depth
  6. Axess SPBT1031 Battery Replacement: paso 6, imagen 1 de 1
    • Separate the black face plate from the tube by pulling them apart.
    • Be careful when pulling the wires apart or it will potentially damage the wires due to over stretching.
  7. Axess SPBT1031 Battery Replacement, Battery: paso 7, imagen 1 de 1
    • Look into the back of the black face plate and find the battery which is wrapped in green.
    • Battery is glued in place, remove by peeling it off.
  8. Axess SPBT1031 Battery Replacement: paso 8, imagen 1 de 1
    • Once the glue is removed, look into the red interface plate and then locate the bottom of the motherboard.
    • On the bottom of the motherboard, locate the black and red wire connected to the plastic red socket and remove the white insert from this socket.
  9. Axess SPBT1031 Battery Replacement: paso 9, imagen 1 de 1
    • Run the black and red wire in reverse through the hole in the black face plate to remove the battery.
    • Remove the battery from the black face plate.
Conclusión
2 personas más completaron esta guía.
3 comentarios
ok, so is there any reason that I would not be able to put in a bigger battery for longer play? I realize I would have to mount it differently.
bartman777 - Contestar
why it is easily connect this blue tooth to cellphone done connecting to computer. Well not connect any of my 3 laptop computer ??????????????
htosee3791 - Contestar
What battery is used for the speaker?
De'Eric Dortch - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 32
Todo El Tiempo: 8,512
