Saltar al contenido principal
Introducción
Use this guide to replace a malfunctioning OLED Board in your Axe Empire 2.0 Marker.
The OLED Board is a screen on a paintball marker that allows you to see text and graphics of your devices settings. A malfunctioning OLED Board can cause your marker to make you unable to modify your devices setting, view important information, or unable to turn the device on at all.
A battery leaking battery acid is unsafe so I recommend you wear gloves when getting in the inside of your Axe Empire 2.0.
In step 1 of this guide, you will need to use an old toothbrush and possibly a rag. Since this device is used with players with other people and constantly getting hit with paint, cleaning out the Allen heads will ensure the correct Allen keys will fit.
  1. Axe Empire 2.0 OLED Board Replacement, OLED Board: paso 1, imagen 1 de 2 Axe Empire 2.0 OLED Board Replacement, OLED Board: paso 1, imagen 2 de 2
    • Use an Allen key to remove four total screws.
    • 2.5 mm screws.
    • 1.2 mm screw.
  2. Axe Empire 2.0 OLED Board Replacement: paso 2, imagen 1 de 3 Axe Empire 2.0 OLED Board Replacement: paso 2, imagen 2 de 3 Axe Empire 2.0 OLED Board Replacement: paso 2, imagen 3 de 3
    • Press and hold the release button while lightly pulling the spring bolt out.
    • If the spring bolt has not been serviced with lube after a long time you might need to pull harder. This is a great time to lube the spring bolt.
  3. Axe Empire 2.0 OLED Board Replacement: paso 3, imagen 1 de 3 Axe Empire 2.0 OLED Board Replacement: paso 3, imagen 2 de 3 Axe Empire 2.0 OLED Board Replacement: paso 3, imagen 3 de 3
    • Remove the two main screws using a 2.5 mm Allen key to separate the air transfer plate from the frame.
  4. Axe Empire 2.0 OLED Board Replacement: paso 4, imagen 1 de 2 Axe Empire 2.0 OLED Board Replacement: paso 4, imagen 2 de 2
    • Remove the screw using a 2.5 mm Allen key and remove the foregrip from the frame.
  5. Axe Empire 2.0 OLED Board Replacement: paso 5, imagen 1 de 2 Axe Empire 2.0 OLED Board Replacement: paso 5, imagen 2 de 2
    • Use a 1.2 mm Allen key to remove the screw, and remove the cover to expose the OLED Board.
  6. Axe Empire 2.0 OLED Board Replacement: paso 6, imagen 1 de 3 Axe Empire 2.0 OLED Board Replacement: paso 6, imagen 2 de 3 Axe Empire 2.0 OLED Board Replacement: paso 6, imagen 3 de 3
    • Remove the last screw with a 2.5 mm Allen key to loosen the OLED Board.
    • Use a pick tool to carefully remove the battery and OLED Board together out of the foregrip.
    • Wear gloves in case battery is defective and leaking acid.
  7. Axe Empire 2.0 OLED Board Replacement: paso 7, imagen 1 de 2 Axe Empire 2.0 OLED Board Replacement: paso 7, imagen 2 de 2
    • Disconnect the battery from the OLED board.
Conclusión
Christopher Ramos
Miembro Desde 05/10/21
345 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 59
