Introducción
This is the replacement guide for the PoE (Power over Ethernet) cable for the AvertX HD810. The only prerequisite for this guide is the Clear Dome Cover. Make sure to completely turn off, power down, and unplug your AvertX HD810 before attempting this operation.
Qué necesitas
Lift off the paintable snap-on cover from the AvertX HD810 dome security camera.
Unscrew the two 10mm screws holding the plastic camera base to the metal camera base using the PH1 screwdriver.
Be aware that cables are still connected under this base, and gently lift the plastic base with the camera away from the metal base with the motherboard.
Disconnect the two cables from the camera base motherboard by gently but firmly pulling directly away from their respective ports.
Disconnect the two PoE (Power over Ethernet) cables from the motherboard by gently but firmly pulling the connected cables directly away from their respective ports.
