Saltar al contenido principal
Autosampler Reset for Node Triggered Sampling (For Old & New Versions)
Qué necesitas
  1. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: paso 1, imagen 1 de 2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: paso 1, imagen 2 de 2
    • To enable manual mode, flip the switch to "Manual Mode"
    • LCD screen will turn on
  2. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: paso 2, imagen 1 de 2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: paso 2, imagen 2 de 2
    • Press On then press Start Sampling
    • Press Enter
  3. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: paso 3, imagen 1 de 3 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: paso 3, imagen 2 de 3 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: paso 3, imagen 3 de 3
    • Press the number of the bottle you want to sample on
    • Press Enter
    • LCD should now show which bottle it will take a sample in
  4. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: paso 4, imagen 1 de 2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: paso 4, imagen 2 de 2
    • To enable autonomous mode, flip switch to "Node Trigger Mode"
    • LCD should turn off
    • If the autosampler is to be remotely triggered, avoid using the ON/OFF button to power off the sampler.
Conclusión
Now the sampler is ready to be triggered remotely by an open-storm sensor node.
Una persona más ha completado esta guía.
Brandon Wong
Miembro Desde 01/16/18
502 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 396
