Saltar al contenido principal
Automatic Tommy 20 Ammo Drum Replacement
Qué necesitas
  1. Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: paso 1, imagen 1 de 2 Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: paso 1, imagen 2 de 2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Ammo Drum Replacement: paso 2, imagen 1 de 3 Automatic Tommy 20 Ammo Drum Replacement: paso 2, imagen 2 de 3 Automatic Tommy 20 Ammo Drum Replacement: paso 2, imagen 3 de 3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: paso 3, imagen 1 de 3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: paso 3, imagen 2 de 3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: paso 3, imagen 3 de 3
    • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
    • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
  4. Automatic Tommy 20 Ammo Drum Replacement: paso 4, imagen 1 de 1
    • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
Conclusión
3 personas más completaron esta guía.
Moira Foster
Miembro Desde 10/09/14
419 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 6-22, Maness Fall 2014 Miembro de Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 763
