Saltar al contenido principal
August Smart Lock Speaker Replacement
Qué necesitas
  1. August Smart Lock Speaker Replacement, Speaker: paso 1, imagen 1 de 3 August Smart Lock Speaker Replacement, Speaker: paso 1, imagen 2 de 3 August Smart Lock Speaker Replacement, Speaker: paso 1, imagen 3 de 3
    • Flip the device so the back cover is facing you.
    • Undo the latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
  2. August Smart Lock Speaker Replacement: paso 2, imagen 1 de 3 August Smart Lock Speaker Replacement: paso 2, imagen 2 de 3 August Smart Lock Speaker Replacement: paso 2, imagen 3 de 3
    • Use the metal spudger to pry the plug off of the motherboard.
    • The plug can be dislodged when prying it from the side.
  3. August Smart Lock Speaker Replacement: paso 3, imagen 1 de 3 August Smart Lock Speaker Replacement: paso 3, imagen 2 de 3 August Smart Lock Speaker Replacement: paso 3, imagen 3 de 3
    • Warm up the iOpener.
    • Do not place the iOpener in microwave for more than 30 seconds.
    • Place the iOpener heating pad over the speaker and let sit for a few moments.
    • Using the metal spudger, pry some of the glue off the hinges holding the speaker in place.
  4. August Smart Lock Speaker Replacement: paso 4, imagen 1 de 2 August Smart Lock Speaker Replacement: paso 4, imagen 2 de 2
    • Once the speaker looks mobile, flip the cover over and push below the speaker to pop it out.
Conclusión
Una persona más ha completado esta guía.
William Fink
Miembro Desde 09/26/17
766 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S11-G6, Passmore Fall 2017 Miembro de USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 1,375
