Saltar al contenido principal
August Smart Lock Gear Replacement
Qué necesitas
  1. August Smart Lock Gear Replacement, Gear: paso 1, imagen 1 de 3 August Smart Lock Gear Replacement, Gear: paso 1, imagen 2 de 3 August Smart Lock Gear Replacement, Gear: paso 1, imagen 3 de 3
    • Flip the device over so the metal plate is facing you.
    • Undo the latches on the side to remove the metal plate.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
  2. August Smart Lock Gear Replacement: paso 2, imagen 1 de 3 August Smart Lock Gear Replacement: paso 2, imagen 2 de 3 August Smart Lock Gear Replacement: paso 2, imagen 3 de 3
    • Lift the cover off the device and set to the side.
    • The cover contains the speaker which is connected to the motherboard so do not pull to far apart.
    • Remove the gears as shown.
Conclusión
11 personas más completaron esta guía.
William Fink
Miembro Desde 09/26/17
766 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S11-G6, Passmore Fall 2017 Miembro de USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Miembros
3 Guías creadas
6 comentarios
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
Walter Quintero - Contestar
Any tips on where to get replacement gears?
Byron H - Contestar
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert F. Jobin Jr. - Contestar
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Luiz Cavalcante -
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
pennytrotz - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 47
Todo El Tiempo: 12,481
