Saltar al contenido principal
August Smart Lock Accelerometer Replacement
Qué necesitas
  1. August Smart Lock Accelerometer Replacement, Accelerometer: paso 1, imagen 1 de 3 August Smart Lock Accelerometer Replacement, Accelerometer: paso 1, imagen 2 de 3 August Smart Lock Accelerometer Replacement, Accelerometer: paso 1, imagen 3 de 3
    • Flip device over so the black bottom is facing you.
    • Undo latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • When you lift off the cover, be careful not to lift to far up. The cover contains the speaker which is connected to the motherboard.
  2. August Smart Lock Accelerometer Replacement: paso 2, imagen 1 de 3 August Smart Lock Accelerometer Replacement: paso 2, imagen 2 de 3 August Smart Lock Accelerometer Replacement: paso 2, imagen 3 de 3
    • Grab the gears and lift them up to remove from the device
  3. August Smart Lock Accelerometer Replacement: paso 3, imagen 1 de 3 August Smart Lock Accelerometer Replacement: paso 3, imagen 2 de 3 August Smart Lock Accelerometer Replacement: paso 3, imagen 3 de 3
    • Remove the (3) three silver screws by the motor using a Phillips #0 screwdriver.
    • Disconnect the speaker plug from the motherboard
    • Disconnect the battery plugs from the motherboard.
  4. August Smart Lock Accelerometer Replacement: paso 4, imagen 1 de 1
    • Once the speaker is disconnected, remove the back cover.
    • Lift up the motherboard and motor assembly out of the device.
  5. August Smart Lock Accelerometer Replacement: paso 5, imagen 1 de 2 August Smart Lock Accelerometer Replacement: paso 5, imagen 2 de 2
    • Locate the Accelerometer. It is attached to the motherboard by a ribbon.
    • Lift up the black tab to remove the ribbon from the motherboard.
Conclusión
7 personas más completaron esta guía.
William Fink
Miembro Desde 09/26/17
742 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S11-G6, Passmore Fall 2017 Miembro de USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Miembros
3 Guías creadas
6 comentarios
Any idea where can I get a new accelerometer to complete this repair?
Thai Nguyen - Contestar
Where can we get a new accelerometer. My phone was not connecting because of the ribbon was broken inside
Dinesh Sharma - Contestar
Same as above…. where to locate an accelerometer??
osallabe - Contestar
Did anyone find out where to buy the part?
LBurd - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 46
Todo El Tiempo: 7,197
