Saltar al contenido principal
Audiovox Tri-mode CDM-9000 Keypad Replacement
Qué necesitas
  1. Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: paso 1, imagen 1 de 3 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: paso 1, imagen 2 de 3 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: paso 1, imagen 3 de 3
    • Flip your phone over so the screen is facing down.
    • About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
  2. Audiovox Tri-mode CDM-9000 Keypad Replacement: paso 2, imagen 1 de 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: paso 2, imagen 2 de 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: paso 2, imagen 3 de 3
    • Once the battery has been removed, you will need a small Phillips 60 mm screwdriver. Remove the two 1.2mm Phillips #1 screws on the back of the phone.
    • Use a spudger tool to pry apart the phone. It may be a little difficult to pry open. Use the flat part of the spudger tool and go all around the phone. It will come apart.
  3. Audiovox Tri-mode CDM-9000 Keypad Replacement: paso 3, imagen 1 de 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: paso 3, imagen 2 de 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: paso 3, imagen 3 de 3
    • Once you have the phone apart simply remove the key pad and replace it with the new one.
    • Don't forget to put the screws back in. Place the battery back on the phone.
    • Push the two parts of the phone back together. You will here a loud click when the phone is back together.
Conclusión
2 personas más completaron esta guía.
Summer Sines
Miembro Desde 09/27/14
406 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 253
