Saltar al contenido principal
Audiovox Tri-mode CDM-9000 Battery Replacement
  1. Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: paso 1, imagen 1 de 3 Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: paso 1, imagen 2 de 3 Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: paso 1, imagen 3 de 3
    • Flip your phone over so the screen is facing down.
    • About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
  2. Audiovox Tri-mode CDM-9000 Battery Replacement, Remove Battery: paso 2, imagen 1 de 2 Audiovox Tri-mode CDM-9000 Battery Replacement, Remove Battery: paso 2, imagen 2 de 2
    • Once the back piece is released, simply lift the battery up and away from the phone.
    • Replace the battery by placing the bottom part of the battery in first and push down. You will hear a loud click sound when the battery is secure.
Conclusión
Una persona más ha completado esta guía.
Summer Sines
Miembro Desde 09/27/14
406 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 372
