Introducción
If the power adapter isn't working, install a new one! This guide shows you how to change out an old power adapter that may not be working right.
Note: This guide involves soldering and should not be done by children. If you do not know how to solder, check out Cómo soldar y desoldar conexiones to learn how before beginning this guide.
Qué necesitas
Turn the device upside down.
Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
One by one, de-solder the two wires that connect the power adapter to your Audiovox.
