Introducción
If the backlight isn't working in your Audiovox CR8030iE5, install a new one! This guide shows you how to change out the old backlight that may not be working right.
Note: This guide involves soldering and should not be done by children. If you do not know how to solder, check out Cómo soldar y desoldar conexiones to learn how before beginning this guide.
Qué necesitas
Turn the device upside down.
Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
Insert a Phillips #1 screwdriver into the corner, square, holes and push the backlight board up away from the plastic casing.
