Introducción
This repair guide will help you with the following:
  • Install the left headphone cable
  • Fix sound coming from the left headphone
  1. Remove the ear pads by peeling them away from the grill.
    • Remove the ear pads by peeling them away from the grill.
    Agregar Comentario
  2. Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
    Agregar Comentario
  3. Reparte el espíritu de reparación esta Navidad
    Obtén $12 de descuento en tu compra de $50 o más con el código FIXMAS12
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
    Agregar Comentario
    • Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference Cómo soldar y desoldar conexiones.
    • The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
    Agregar Comentario
    • Untie the knot in the thick main cable.
    • Remove the main cable from the headphones by pulling it out.
    • Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
    Agregar Comentario
    • Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference Cómo soldar y desoldar conexiones.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
    Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Melanie Reis
Miembro Desde 11/01/13
121 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 17-19, Forte Winter 2013 Miembro de Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Miembros
6 Guías creadas
Thank you so much! your guide helped me repair my AD900x!
Anwar X - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 12
Últimos 30 Días: 84
Todo El Tiempo: 4,956
