Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Atari Lynx Battery Wire Replacement
Qué necesitas
    1. Atari Lynx Battery Wire Replacement, Atari Lynx: paso 1, imagen 1 de 1
      • Before disassembling your Atari Lynx, be sure the device is powered off.
      • Remove any game in the console by opening the right latch and sliding the game to the right.
      Pregunta a FixBot
      Agregar Comentario
    2. Atari Lynx Battery Wire Replacement: paso 2, imagen 1 de 1
      • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
      • Pinch the rear panel with your fingers and lift away from the Atari.
      Pregunta a FixBot
      Agregar Comentario
    3. Atari Lynx Battery Wire Replacement: paso 3, imagen 1 de 1
      • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
      • Be sure not to tear any wires attached to battery panel.
      Pregunta a FixBot
      Agregar Comentario
    4. Atari Lynx Battery Wire Replacement: paso 4, imagen 1 de 1
      • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
      • Be sure not to tear the speaker wire while removing the control panel.
      Pregunta a FixBot
      Agregar Comentario
    1. Atari Lynx Battery Wire Replacement, Battery Wires: paso 5, imagen 1 de 1
      • Desolder both the black and red wire as shown.
      • If you need help with basic desoldering, click here.
      Pregunta a FixBot
      Agregar Comentario
    2. Atari Lynx Battery Wire Replacement: paso 6, imagen 1 de 1
      • Desolder the black wire as shown.
      Pregunta a FixBot
      Agregar Comentario
    3. Atari Lynx Battery Wire Replacement: paso 7, imagen 1 de 2 Atari Lynx Battery Wire Replacement: paso 7, imagen 2 de 2
      • Desolder the white wire and then the red wire as shown.
      Pregunta a FixBot
      Agregar Comentario
    4. Atari Lynx Battery Wire Replacement: paso 8, imagen 1 de 1
      • Desolder the white wire as shown in order for the battery pack to be completely removed from the device.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
John Lopez
Miembro Desde 01/27/14
446 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 1-42, Maness Winter 2014 Miembro de Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
Miembros de 5
72 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 51
Todo El Tiempo: 2,492
