Saltar al contenido principal
Atari Flashback 2 Reset and Select Button Replacement
Qué necesitas
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: paso 1, imagen 1 de 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: paso 1, imagen 2 de 3 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: paso 1, imagen 3 de 3
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Reset and Select Button Replacement: paso 2, imagen 1 de 3 Atari Flashback 2 Reset and Select Button Replacement: paso 2, imagen 2 de 3 Atari Flashback 2 Reset and Select Button Replacement: paso 2, imagen 3 de 3
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
Conclusión
Equipo
2 comentarios
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - Contestar
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 707
