Saltar al contenido principal
Atari Flashback 2 Joystick Button Replacement
Qué necesitas
  1. Atari Flashback 2 Joystick Button Replacement, Joystick Button: paso 1, imagen 1 de 1
    • Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
    • Remove the bottom panel from the joystick.
  2. Atari Flashback 2 Joystick Button Replacement: paso 2, imagen 1 de 1
    • Unscrew the single 8.0 mm Phillips#1 screw holding the circuit board in place.
    • Remove the circuit board from the joystick housing.
  3. Atari Flashback 2 Joystick Button Replacement: paso 3, imagen 1 de 1
    • Inspect the circuit board for dirt, corrosion or damage. If necessary, clean the indicated contact using a cotton swab.
  4. Atari Flashback 2 Joystick Button Replacement: paso 4, imagen 1 de 1
    • Remove the button from the joystick housing. Check for dirt or debris that may obstruct its movement. If the button is broken, replace it.
Conclusión
Daniel Hoffman
Miembro Desde 09/17/18
209 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 375
