Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Atari Flashback 2 Console Power Button Replacement
Qué necesitas
  1. Atari Flashback 2 Console Power Button Replacement, Console Power Button: paso 1, imagen 1 de 3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: paso 1, imagen 2 de 3 Atari Flashback 2 Console Power Button Replacement, Console Power Button: paso 1, imagen 3 de 3
    • Using the screwdriver and PH1 bit, unscrew the five 10.0 mm screws.
    • One is under the main sticker in the middle of the console.
    Pregunta a FixBot
  2. Atari Flashback 2 Console Power Button Replacement: paso 2, imagen 1 de 3 Atari Flashback 2 Console Power Button Replacement: paso 2, imagen 2 de 3 Atari Flashback 2 Console Power Button Replacement: paso 2, imagen 3 de 3
    • Use a PH1 screwdriver to unscrew the two 9.0 mm screws on the circuit board that corresponds to the red power button.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    • A spring may pop out.
    Pregunta a FixBot
Conclusión
Faith Julian
Miembro Desde 09/18/18
205 Reputación
2 Guías creadas
Equipo
1Guía Comentario
Hello. I just bought a used atari flashback 2 and when I turn it on it seems that the power button is a little tricky. I wiggle the button in and out and half way etc. then sometimes I can get it to turn on. Once on, the video 'pulses' on and off and a pulsing sound is noticeable. Is it just a faulty power button or is it something worse like a power regulator. I've taken it apart and all seems to be ok looking ie. no burnt fuses etc.  Can you help?  ~Brad Beachin~
bradbeachin - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 96
Todo El Tiempo: 1,351
