Saltar al contenido principal
Atari 5200 number pad cleaning or replacement
Qué necesitas
  1. Atari 5200 number pad cleaning or replacement, Open the controller: paso 1, imagen 1 de 3 Atari 5200 number pad cleaning or replacement, Open the controller: paso 1, imagen 2 de 3 Atari 5200 number pad cleaning or replacement, Open the controller: paso 1, imagen 3 de 3
    • Turn the controller over, exposing the three screws on the back (marked by the orange circles). Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    • Try not to move the joystick when reassembling. This will almost assuredly break your alignment. The less the joystick is moved, the easier it will be to realign the joystick to the pots.
  2. Atari 5200 number pad cleaning or replacement, Cleaning/Reseating (number pad front and back): paso 2, imagen 1 de 3 Atari 5200 number pad cleaning or replacement, Cleaning/Reseating (number pad front and back): paso 2, imagen 2 de 3 Atari 5200 number pad cleaning or replacement, Cleaning/Reseating (number pad front and back): paso 2, imagen 3 de 3
    • Take out the rubber button module of the number pad.
    • With access to the number pad sensors, use compressed air to blow out dust.
    • Wipe the sensors clean with a cloth dabbed with alcohol.
  3. Atari 5200 number pad cleaning or replacement, Reassembly Part 1: paso 3, imagen 1 de 2 Atari 5200 number pad cleaning or replacement, Reassembly Part 1: paso 3, imagen 2 de 2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Atari 5200 number pad cleaning or replacement, Reassembly Part 2: paso 4, imagen 1 de 2 Atari 5200 number pad cleaning or replacement, Reassembly Part 2: paso 4, imagen 2 de 2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  5. Atari 5200 number pad cleaning or replacement, Reassembly Part 3: paso 5, imagen 1 de 3 Atari 5200 number pad cleaning or replacement, Reassembly Part 3: paso 5, imagen 2 de 3 Atari 5200 number pad cleaning or replacement, Reassembly Part 3: paso 5, imagen 3 de 3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
Conclusión
Una persona más ha completado esta guía.
Alan Abelson
Miembro Desde 09/26/14
233 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 13-1, Staggers Fall 2014 Miembro de USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 17
Todo El Tiempo: 528
