Saltar al contenido principal
Atari 5200 Joystick Repair
Qué necesitas
  1. Atari 5200 Joystick Repair, Opening the Controller: paso 1, imagen 1 de 3 Atari 5200 Joystick Repair, Opening the Controller: paso 1, imagen 2 de 3 Atari 5200 Joystick Repair, Opening the Controller: paso 1, imagen 3 de 3
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
  2. Atari 5200 Joystick Repair, Locating the Knobs and Pots: paso 2, imagen 1 de 1
    • Find the knobs (closest to the joystick and circled in red).
    • Locate the pots (closest to the circuitry and circled in orange). Keep track of these.
    • Align the joystick's metal bar into its cup.
    • Don't move any of the button circuitry, especially those of the START/PAUSE/RESET buttons.
  3. Atari 5200 Joystick Repair, Reassembly Part 1: paso 3, imagen 1 de 1
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Atari 5200 Joystick Repair, Reassembly Part 2: paso 4, imagen 1 de 2 Atari 5200 Joystick Repair, Reassembly Part 2: paso 4, imagen 2 de 2
    • Realign the top and bottom of the controller.
    • Pull the circuit strip through the new space.
  5. Atari 5200 Joystick Repair, Reassembly Part 3: paso 5, imagen 1 de 3 Atari 5200 Joystick Repair, Reassembly Part 3: paso 5, imagen 2 de 3 Atari 5200 Joystick Repair, Reassembly Part 3: paso 5, imagen 3 de 3
    • Return the start buttons to the top of the controller
    • Snap the frame back into place
    • Screw in the three screws on the back.
Linea de Meta
4 personas más completaron esta guía.
Alan Abelson
Miembro Desde 09/26/14
233 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 13-1, Staggers Fall 2014 Miembro de USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 42
Todo El Tiempo: 2,925
