Saltar al contenido principal
Atari 5200 Game Cartridge Disassembly
Qué necesitas
  1. Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: paso 1, imagen 1 de 3 Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: paso 1, imagen 2 de 3 Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: paso 1, imagen 3 de 3
    • Flip the cartridge over.
    • Unscrew the single screw on the back.
    • Carefully pry apart the casing. There are six (6) tabs that need to be released, three (3) each side. If you're not careful they will break. (experience has taught me)
    • Set aside any case parts after dissassembly.
  2. Atari 5200 Game Cartridge Disassembly, Cleaning the Parts: paso 2, imagen 1 de 1
    • Unscrew the board casing, and remove it.
    • Use a compressed air can to blow off any excess dust off the board.
    • Use an alcohol-dabbed cloth to wipe down the gold-plated contacts of the board.
  3. Atari 5200 Game Cartridge Disassembly, Reassembly: paso 3, imagen 1 de 3 Atari 5200 Game Cartridge Disassembly, Reassembly: paso 3, imagen 2 de 3 Atari 5200 Game Cartridge Disassembly, Reassembly: paso 3, imagen 3 de 3
    • Place the two contact protectors together.
    • Place the spring on the knob in the cartridge.
  4. Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: paso 4, imagen 1 de 3 Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: paso 4, imagen 2 de 3 Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: paso 4, imagen 3 de 3
    • Thread the spring into the connected plates.
    • Push the plates into the cartridge against the pressure of the spring.
  5. Atari 5200 Game Cartridge Disassembly, Finishing up: paso 5, imagen 1 de 3 Atari 5200 Game Cartridge Disassembly, Finishing up: paso 5, imagen 2 de 3 Atari 5200 Game Cartridge Disassembly, Finishing up: paso 5, imagen 3 de 3
    • Place the chip in the case.
    • It should "pop" into place.
    • Screw the other side of the case on.
Conclusión
Be sure to test the game, and if freezing still occurs, check the contacts once again.
3 personas más completaron esta guía.
Equipo
USF Tampa, Team 13-1, Staggers Fall 2014 Miembro de USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Miembros
17 Guías creadas
2 comentarios
I’m curious to see the Atari 2600 cartridge inside but I can’t get my hands on one.
The official meme centre. - Contestar
it's not a 2600 cart. the systems have similarities, but they are not pin compatible, nor are they software compatible. the 5200 is its own thing.
Gorilla Sapiens - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 27
Todo El Tiempo: 2,715
