Saltar al contenido principal
Atari 5200 Motherboard Cleaning
Qué necesitas
  1. Atari 5200 Motherboard Cleaning, Atari 5200 Motherboard Cleaning: paso 1, imagen 1 de 1
    • Flip your Atari Entertainment System over to its top so you can see the bottom. You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
  2. Atari 5200 Motherboard Cleaning: paso 2, imagen 1 de 1
    • Flip the Atari Entertainment System back over so that you can now see the top.
    • Use your hands to gently remove the top by sliding it off.
  3. Atari 5200 Motherboard Cleaning, Access: Granted: paso 3, imagen 1 de 1
    • You will now have access to the motherboard.
    • The motherboard can be cleaned with a moist paper towel.
    • Be sure the motherboard is fully dry before playing your Atari Entertainment System or you may damage it!
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team 13-1, Staggers Fall 2014 Miembro de USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
5 Miembros
17 Guías creadas
Un comentario
This "tutorial" does not even cover gaining access to the motherboard.
Dannot - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 2,617
