Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Atari 5200 Controller Side Buttons Replacement
Qué necesitas
  1. Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: paso 1, imagen 1 de 3 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: paso 1, imagen 2 de 3 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: paso 1, imagen 3 de 3
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    Pregunta a FixBot
  2. Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: paso 2, imagen 1 de 2 Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: paso 2, imagen 2 de 2
    • Now that the top of the controller is exposed, the orange, side buttons can easily slide out.
    • Realign the buttons over the sensors/clean the sensor contacts.
    • Be careful when reassembling your buttons. Make sure the black buttons are aligned properly over the silver sensors on the flex board
    • Also, be careful to properly align the bottom of the joystick with the pots (white levers)
    Pregunta a FixBot
  3. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: paso 3, imagen 1 de 2 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: paso 3, imagen 2 de 2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
    Pregunta a FixBot
  4. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: paso 4, imagen 1 de 2 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: paso 4, imagen 2 de 2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
    Pregunta a FixBot
  5. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: paso 5, imagen 1 de 3 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: paso 5, imagen 2 de 3 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: paso 5, imagen 3 de 3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
    Pregunta a FixBot
Conclusión
Una persona más ha completado esta guía.
Alan Abelson
Miembro Desde 09/26/14
233 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 13-1, Staggers Fall 2014 Miembro de USF Tampa, Team 13-1, Staggers Fall 2014
USFT-STAGGERS-F14S13G1
Miembros de 5
17 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 51
Todo El Tiempo: 1,390
