Saltar al contenido principal
Asus Zenfone 5 Power and Volume Flex Cable Replacement
Qué necesitas
  1. Asus Zenfone 5 Power and Volume Flex Cable Replacement, Back Cover: paso 1, imagen 1 de 3 Asus Zenfone 5 Power and Volume Flex Cable Replacement, Back Cover: paso 1, imagen 2 de 3 Asus Zenfone 5 Power and Volume Flex Cable Replacement, Back Cover: paso 1, imagen 3 de 3
    • Start by locating the small opener tab at the bottom-left corner of the phone.
    • Remove the entire back cover.
    • Use a plastic opening tool to make it easier to open. Here I'm simply using a cosmetic tweezer as I don't have one.
    • It did leave a mark a bit but doesn't matter to me.
  2. Asus Zenfone 5 Power and Volume Flex Cable Replacement, Midframe: paso 2, imagen 1 de 1
    • Remove the following screws:
    • 3 shorter Phillips #00 screws
    • 10 longer Phillips #00 screws
    • One of my longer screws is missing, don't know when I lost it.
    • Gently lift the midframe up.
    • There might be some adhesive beneath these, just keep lifting it up gently.
  3. Asus Zenfone 5 Power and Volume Flex Cable Replacement, Motherboard: paso 3, imagen 1 de 3 Asus Zenfone 5 Power and Volume Flex Cable Replacement, Motherboard: paso 3, imagen 2 de 3 Asus Zenfone 5 Power and Volume Flex Cable Replacement, Motherboard: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Spudger
    $2.99
    Comprar
    • Identify these:
    • Flex Cable connector
    • Power and Volume Button Flex Cable itself
    • Battery Power connector
    • First disconnect the power line by gently lifting the Battery Power connector up to prevent accidental power-on.
    • Use a spudger to make it easier to lift it up.
    • Gently pull the Flex Cable connector off from its port.
    • Use a pair of tweezers to make it easier to pull it off.
  4. Asus Zenfone 5 Power and Volume Flex Cable Replacement, Flex Cable: paso 4, imagen 1 de 2 Asus Zenfone 5 Power and Volume Flex Cable Replacement, Flex Cable: paso 4, imagen 2 de 2
    • Take the old Flex Cable off.
    • Replace the Flex Cable that you've taken off with the new one.
    • The broken one
    • The new one
    • Take the sticker for securing the adhesive off from the new one.
    • Carefully place it.
    • Proceed to the conclusion.
Conclusión
7 personas más completaron esta guía.
Cakra Diaz
Miembro Desde 07/26/17
999 Reputación
6 Guías creadas
Un comentario
Ahhh! Why Asus mobile phones aren't long lasting. My device is taking long time while charging and it drains too fast. I've also Asus Zenfone max pro m1, and its headphone jack has been stopped to working
Jeet singh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 3,941
