Saltar al contenido principal
Asus Zenfone 4 Max Screen Replacement
Qué necesitas
  1. Asus Zenfone 4 Max Screen Replacement, Battery: paso 1, imagen 1 de 2 Asus Zenfone 4 Max Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
  2. Asus Zenfone 4 Max Screen Replacement: paso 2, imagen 1 de 1
    • Gently wedge the opening tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  3. Asus Zenfone 4 Max Screen Replacement: paso 3, imagen 1 de 3 Asus Zenfone 4 Max Screen Replacement: paso 3, imagen 2 de 3 Asus Zenfone 4 Max Screen Replacement: paso 3, imagen 3 de 3
    • Once the back has been removed, you will need to unscrew the four screws on the bottom panel with an AT3 bit.
  4. Asus Zenfone 4 Max Screen Replacement: paso 4, imagen 1 de 1
    • Remove the bottom panel.
  5. Asus Zenfone 4 Max Screen Replacement: paso 5, imagen 1 de 2 Asus Zenfone 4 Max Screen Replacement: paso 5, imagen 2 de 2
    • Wedge an opening tool between the battery and phone.
    • Gently pry the battery out of the device.
    • You can move the opening on either side of the battery as well as the bottom to aid in removal.
  6. Asus Zenfone 4 Max Screen Replacement: paso 6, imagen 1 de 1
    • Remove the battery and replace it with the new battery.
  7. Asus Zenfone 4 Max Screen Replacement, Camera: paso 7, imagen 1 de 1
    • Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
  8. Asus Zenfone 4 Max Screen Replacement: paso 8, imagen 1 de 1
    • Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
    • Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
    • Gently move the tool around the edges towards each corner until the back is removed.
    • You will be able to hear the back casing pulling apart from the phone. Do not be alarmed, but work gently with the device.
  9. Asus Zenfone 4 Max Screen Replacement: paso 9, imagen 1 de 2 Asus Zenfone 4 Max Screen Replacement: paso 9, imagen 2 de 2
    • Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
  10. Asus Zenfone 4 Max Screen Replacement: paso 10, imagen 1 de 3 Asus Zenfone 4 Max Screen Replacement: paso 10, imagen 2 de 3 Asus Zenfone 4 Max Screen Replacement: paso 10, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the tweezers to gently pull up on the flaps beneath the two cameras.
    • Completely remove the cameras and replace with the new cameras.
  11. Asus Zenfone 4 Max Screen Replacement, Screen: paso 11, imagen 1 de 3 Asus Zenfone 4 Max Screen Replacement, Screen: paso 11, imagen 2 de 3 Asus Zenfone 4 Max Screen Replacement, Screen: paso 11, imagen 3 de 3
    • Using the screwdriver with the PH0 bit, unscrew all screws found on the circuit board.
  12. Asus Zenfone 4 Max Screen Replacement: paso 12, imagen 1 de 1
    • Carefully disconnect the power cable on the right side of the circuit board.
    • Leave the disconnected cable hanging as it will be used again later.
    • Use as little force as possible seeing that the power cable is very fragile.
  13. Asus Zenfone 4 Max Screen Replacement: paso 13, imagen 1 de 1
    • Gently lift and remove the circuit board.
  14. Asus Zenfone 4 Max Screen Replacement: paso 14, imagen 1 de 2 Asus Zenfone 4 Max Screen Replacement: paso 14, imagen 2 de 2
    • Disconnect the power cable on the right side of the device and leave it hanging in place.
  15. Asus Zenfone 4 Max Screen Replacement: paso 15, imagen 1 de 1
    • Using a metal spudger, separate the screen from the entire device by gently moving the tool around all edges.
    • It could be useful to use a blow-dryer to heat the screen for a smoother removal.
  16. Asus Zenfone 4 Max Screen Replacement: paso 16, imagen 1 de 3 Asus Zenfone 4 Max Screen Replacement: paso 16, imagen 2 de 3 Asus Zenfone 4 Max Screen Replacement: paso 16, imagen 3 de 3
    • Gently separate the screen from the phone by pulling the two apart.
    • The power cables will be fed through the slots of the phone. Make sure the top power cable is disconnected and is removed along with the screen.
Conclusión
4 personas más completaron esta guía.
Rachel Hodgdon
Miembro Desde 10/02/18
245 Reputación
1 Guía escrita
Equipo
2 comentarios
in one step it says use a T3 for to the left and right of the charging port, later it says T4. also, the guide has what i believe to be a typo, as it mentions an “AT3” bit for removal of the internal bottom panel. just wanted to alert you to these inconsistencies. overall seems to be a good guide, i shall be replacing my screen soon as i have cracked the corner and find it unsightly. thank you, have a nice evening.
Ronald Bloodworth - Contestar
This was a fun fix, usually I fix iPad or iPhone, so this was my first time fixing an Asus and was easier than I thought it was gonna be. Just take your time as I didn't now I'm fixing something else .
Sir Frank Macias - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 58
Todo El Tiempo: 7,388
