Saltar al contenido principal
Asus Zenfone 4 Max Camera Replacement
Qué necesitas
  1. Asus Zenfone 4 Max Camera Replacement, Camera: paso 1, imagen 1 de 1
    • Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
  2. Asus Zenfone 4 Max Camera Replacement: paso 2, imagen 1 de 1
    • Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
    • Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
    • Gently move the tool around the edges towards each corner until the back is removed.
    • You will be able to hear the back casing pulling apart from the phone. Do not be alarmed, but work gently with the device.
  3. Asus Zenfone 4 Max Camera Replacement: paso 3, imagen 1 de 2 Asus Zenfone 4 Max Camera Replacement: paso 3, imagen 2 de 2
    • Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
  4. Asus Zenfone 4 Max Camera Replacement: paso 4, imagen 1 de 3 Asus Zenfone 4 Max Camera Replacement: paso 4, imagen 2 de 3 Asus Zenfone 4 Max Camera Replacement: paso 4, imagen 3 de 3
    • Use the tweezers to gently pull up on the flaps beneath the two cameras.
    • Completely remove the cameras and replace with the new cameras.
Conclusión
Maegan West
Miembro Desde 10/02/18
839 Reputación
4 Guías creadas
Equipo
2 comentarios
You can read T3 in the summary and T4 in the instructions: which one do I need?
patriziomaugeri - Contestar
Does this fix the Zenfone 4 max camera black screen?
Roger Dufault - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 1,935
