Saltar al contenido principal
Asus Zenbook UX550GE-XB71T Battery Replacement
Qué necesitas
  1. Asus Zenbook UX550GE-XB71T Battery Replacement, Battery: paso 1, imagen 1 de 2 Asus Zenbook UX550GE-XB71T Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn computer off and disconnect it from power.
    • Flip it over so the backside is facing you.
  2. Asus Zenbook UX550GE-XB71T Battery Replacement: paso 2, imagen 1 de 2 Asus Zenbook UX550GE-XB71T Battery Replacement: paso 2, imagen 2 de 2
    • Using the T5 Torx screwdriver, remove the ten screws under the computer.
    • Gently remove the back cover from the device.
  3. Asus Zenbook UX550GE-XB71T Battery Replacement: paso 3, imagen 1 de 1
    • Using the Phillips #00 screwdriver, remove the four screws along the battery.
  4. Asus Zenbook UX550GE-XB71T Battery Replacement: paso 4, imagen 1 de 3 Asus Zenbook UX550GE-XB71T Battery Replacement: paso 4, imagen 2 de 3 Asus Zenbook UX550GE-XB71T Battery Replacement: paso 4, imagen 3 de 3
    • Disconnect the ribbon cable by pushing upwards on the ZIF connector.
  5. Asus Zenbook UX550GE-XB71T Battery Replacement: paso 5, imagen 1 de 1
    • Disconnect and remove the battery from the device.
Conclusión
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 61
Todo El Tiempo: 999
