Introducción
Use this guide to replace noisy or malfunctioning GPU fan in the Asus Zenbook UX32VD.
Herramientas
Partes
No se especificaron partes.
Remove the twelve 3 mm bottom panel screws with a T5 Torx Screwdriver.
Use the tip of your spudger or your fingernail to open the ZIF connector on the I/O board.
Remove the metallic ribbon cable from the connector .
Casi Terminas!
Conclusión
