Saltar al contenido principal
Asus Zenbook UX32VD GPU Fan Replacement
Qué necesitas
  1. Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: paso 1, imagen 1 de 3 Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: paso 1, imagen 2 de 3 Asus Zenbook UX32VD GPU Fan Replacement, Bottom Panel: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    T5 Torx Screwdriver
    $9.99
    Comprar
  2. Asus Zenbook UX32VD GPU Fan Replacement: paso 2, imagen 1 de 3 Asus Zenbook UX32VD GPU Fan Replacement: paso 2, imagen 2 de 3 Asus Zenbook UX32VD GPU Fan Replacement: paso 2, imagen 3 de 3
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD GPU Fan Replacement, Fan: paso 3, imagen 1 de 3 Asus Zenbook UX32VD GPU Fan Replacement, Fan: paso 3, imagen 2 de 3 Asus Zenbook UX32VD GPU Fan Replacement, Fan: paso 3, imagen 3 de 3
    Spudger
    $2.99
    Comprar
    • Use the tip of your spudger or your fingernail to open the ZIF connector on the I/O board.
    • Be sure to pry up on the hinged retaining flap, not the connector itself.
    • Remove the metallic ribbon cable from the connector .
    • No force is needed to remove or insert the cable.
  4. Asus Zenbook UX32VD GPU Fan Replacement: paso 4, imagen 1 de 3 Asus Zenbook UX32VD GPU Fan Replacement: paso 4, imagen 2 de 3 Asus Zenbook UX32VD GPU Fan Replacement: paso 4, imagen 3 de 3
    Phillips #0 Screwdriver
    $5.49
    Comprar
  5. Asus Zenbook UX32VD GPU Fan Replacement: paso 5, imagen 1 de 3 Asus Zenbook UX32VD GPU Fan Replacement: paso 5, imagen 2 de 3 Asus Zenbook UX32VD GPU Fan Replacement: paso 5, imagen 3 de 3
    • Unplug the bundled cable connector.
    • Move the fan as shown in the first picture to better access the connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Asus Zenbook UX32VD GPU Fan Replacement: paso 6, imagen 1 de 1
    • Remove the fan completely.
Conclusión
Equipo
CSU Fullerton, Team 2-2, Bruce Fall 2015 Miembro de CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 2,195
