Saltar al contenido principal
Asus Zenbook UX32VD Battery Replacement
Qué necesitas
  1. Asus Zenbook UX32VD Battery Replacement, Bottom Panel: paso 1, imagen 1 de 3 Asus Zenbook UX32VD Battery Replacement, Bottom Panel: paso 1, imagen 2 de 3 Asus Zenbook UX32VD Battery Replacement, Bottom Panel: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    T5 Torx Screwdriver
    $9.99
    Comprar
  2. Asus Zenbook UX32VD Battery Replacement: paso 2, imagen 1 de 3 Asus Zenbook UX32VD Battery Replacement: paso 2, imagen 2 de 3 Asus Zenbook UX32VD Battery Replacement: paso 2, imagen 3 de 3
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD Battery Replacement, Battery: paso 3, imagen 1 de 2 Asus Zenbook UX32VD Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the eight 3 mm Phillips #0 screws on the bottom panel.
  4. Asus Zenbook UX32VD Battery Replacement: paso 4, imagen 1 de 2 Asus Zenbook UX32VD Battery Replacement: paso 4, imagen 2 de 2
    • Pry up each side of the flat connectors by hand or with a plastic opening tool.
    • Lift the connector straight up from its socket.
  5. Asus Zenbook UX32VD Battery Replacement: paso 5, imagen 1 de 3 Asus Zenbook UX32VD Battery Replacement: paso 5, imagen 2 de 3 Asus Zenbook UX32VD Battery Replacement: paso 5, imagen 3 de 3
    • Unplug the two bundled cable connectors on each side of the battery.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Asus Zenbook UX32VD Battery Replacement: paso 6, imagen 1 de 1
    • Remove the battery completely.
Conclusión
4 personas más completaron esta guía.
Jenny Nguy
Miembro Desde 09/17/15
177 Reputación
1 Guía escrita
Equipo
CSU Fullerton, Team 2-2, Bruce Fall 2015 Miembro de CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Miembros
6 Guías creadas
5 comentarios
what is the color code of the battery wiring? especially for the white and yellow
Asim Ahmed - Contestar
Will this method also apply to ASUS Zenbook UX430UQ ?
Kurt Scheel - Contestar
Is this the same method for ASUS Zenbook UX430UQ-GV050T ?
this is probably odd, but can someone recommend me battery and speakers?
I did small research, have not found any speakers and found a few options with battery, but all of them looks suspicious, some comments like - dead after 1 year and etc...
Regards
Nikolay Em - Contestar
Why would you replace the speakers? I don't ever understand, why would you unplug the speakers (as it's done in these instructions)? They are just taped on side of the battery, once you lift up the battery a little bit, you can take the speakers off from the battery pack and leave them on their place while replacing the battery.
Touko Korpela - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 21
Ultimos 30 días: 54
Todo El Tiempo: 17,713
