Saltar al contenido principal
Asus Zenbook UX32VD HD Web Camera Replacement
Qué necesitas
  1. Asus Zenbook UX32VD  HD Web Camera Replacement, HD Web Camera: paso 1, imagen 1 de 1
    • Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
    • Use low heat with the heat gun. Over heating could damage delicate electronic components.
  2. Asus Zenbook UX32VD  HD Web Camera Replacement: paso 2, imagen 1 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: paso 2, imagen 2 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: paso 2, imagen 3 de 3
    Herramienta utilizada en este paso:
    Metal Spudger Set
    $7.99
    Comprar
    • Insert a spudger between the display screen frame and the back screen panel.
    • Pry the display screen frame away from the back screen panel.
    • Continue to heat and remove the display screen frame along the whole perimeter.
  3. Asus Zenbook UX32VD  HD Web Camera Replacement: paso 3, imagen 1 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: paso 3, imagen 2 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: paso 3, imagen 3 de 3
    • Remove display screen frame completely before adhesive cools and hardens.
  4. Asus Zenbook UX32VD  HD Web Camera Replacement: paso 4, imagen 1 de 2 Asus Zenbook UX32VD  HD Web Camera Replacement: paso 4, imagen 2 de 2
    • Unplug the bundled cable connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  5. Asus Zenbook UX32VD  HD Web Camera Replacement: paso 5, imagen 1 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: paso 5, imagen 2 de 3 Asus Zenbook UX32VD  HD Web Camera Replacement: paso 5, imagen 3 de 3
    Spudger
    $2.99
    Comprar
    • Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
    • Remove the camera completely.
Conclusión
Michael Remmel
Miembro Desde 09/17/15
709 Reputación
3 Guías creadas
Equipo
CSU Fullerton, Team 2-2, Bruce Fall 2015 Miembro de CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Miembros
6 Guías creadas
2 comentarios
what type/model/code for its replacement camera ? so i cant find it in part store...
tukangsedot - Contestar
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
Mehran Gerami - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 1,864
