Saltar al contenido principal
Asus Zenbook UX31E Fan Replacement
Qué necesitas
  1. Asus Zenbook UX31E Fan Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Fan Replacement: paso 2, imagen 1 de 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Fan Replacement, Fan: paso 3, imagen 1 de 2 Asus Zenbook UX31E Fan Replacement, Fan: paso 3, imagen 2 de 2
    • Disconnect the ribbon between the IO and the motherboard on both sides.
  4. Asus Zenbook UX31E Fan Replacement: paso 4, imagen 1 de 1
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  5. Asus Zenbook UX31E Fan Replacement: paso 5, imagen 1 de 2 Asus Zenbook UX31E Fan Replacement: paso 5, imagen 2 de 2
    • Unscrew the two screws that are across each other.
  6. Asus Zenbook UX31E Fan Replacement: paso 6, imagen 1 de 2 Asus Zenbook UX31E Fan Replacement: paso 6, imagen 2 de 2
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
Conclusión
Sinh
Miembro Desde 02/01/17
101 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team 1-2, Rose Winter 2017 Miembro de UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Miembros
9 Guías creadas
Un comentario
This guide does not explain how to replace the fan, but how to remove the fan.
How do you insert a new fan? (Specifically, how do you remove the fan from the component of which it is a part?)
Thank you in advance.
Albert - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,742
