Saltar al contenido principal
Asus Zenbook UX31E Battery Replacement
Qué necesitas
  1. Asus Zenbook UX31E Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
  2. Asus Zenbook UX31E Battery Replacement: paso 2, imagen 1 de 1
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Battery Replacement, Battery: paso 3, imagen 1 de 2 Asus Zenbook UX31E Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Disconnect the battery from the motherboard by gently pulling up and down on the connector.
  4. Asus Zenbook UX31E Battery Replacement: paso 4, imagen 1 de 2 Asus Zenbook UX31E Battery Replacement: paso 4, imagen 2 de 2
    • Using the Phillips #00 screwdriver, remove the screws from the middle and the two corners of the battery.
  5. Asus Zenbook UX31E Battery Replacement: paso 5, imagen 1 de 2 Asus Zenbook UX31E Battery Replacement: paso 5, imagen 2 de 2
    • Remove the battery. (Picture-1)
    • Picture of what the battery looks like.(Picture-2)
Conclusión
5 personas más completaron esta guía.
Hersi Dahir
Miembro Desde 02/02/17
203 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team 1-2, Rose Winter 2017 Miembro de UW Tacoma, Team 1-2, Rose Winter 2017
UWT-ROSE-W17S1G2
4 Miembros
9 Guías creadas
2 comentarios
Thanks for the easy to understand guide. Cheers!
Rahul Kashelani - Contestar
Thanks for the guideline it easy to understand and easy to follow. Thanks again!
fiddyfadhlina - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 32
Todo El Tiempo: 7,899
