Saltar al contenido principal
Asus Zenbook UX31A Wi-Fi Card Replacement
Qué necesitas
  1. Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: paso 1, imagen 1 de 2 Asus Zenbook UX31A Wi-Fi Card Replacement, Wi-Fi Card: paso 1, imagen 2 de 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
  2. Asus Zenbook UX31A Wi-Fi Card Replacement: paso 2, imagen 1 de 2 Asus Zenbook UX31A Wi-Fi Card Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 6 mm screws that secure the Wi-Fi card.
    • Wires are loose and easy to disconnect.
  3. Asus Zenbook UX31A Wi-Fi Card Replacement: paso 3, imagen 1 de 1
    • Gently pull the the Wi-Fi card from the motherboard.
    • Disconnect the white and black wire by gently pulling each one up.
    • They can be a little tricky to put back on so take your time and be gentle.
Conclusión
Sherwin
Miembro Desde 03/22/22
209 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 376
