Saltar al contenido principal
Asus Zenbook UX31A Daughterboard Replacement
Qué necesitas
  1. Asus Zenbook UX31A Daughterboard Replacement, Battery: paso 1, imagen 1 de 2 Asus Zenbook UX31A Daughterboard Replacement, Battery: paso 1, imagen 2 de 2
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Daughterboard Replacement: paso 2, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Daughterboard Replacement: paso 3, imagen 1 de 1
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Daughterboard Replacement: paso 4, imagen 1 de 1
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Daughterboard Replacement, Fan: paso 5, imagen 1 de 2 Asus Zenbook UX31A Daughterboard Replacement, Fan: paso 5, imagen 2 de 2
    • Unclip both ZIF connector tabs by lifting the black tab up and away from the connector.
    • Remove the bridge connector.
  6. Asus Zenbook UX31A Daughterboard Replacement: paso 6, imagen 1 de 3 Asus Zenbook UX31A Daughterboard Replacement: paso 6, imagen 2 de 3 Asus Zenbook UX31A Daughterboard Replacement: paso 6, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove all seven 6 mm screws that secure the fan and heatsink.
  7. Asus Zenbook UX31A Daughterboard Replacement: paso 7, imagen 1 de 2 Asus Zenbook UX31A Daughterboard Replacement: paso 7, imagen 2 de 2
    • Disconnect the fan connector by pulling on it horizontally until it disconnects.
    • Remove the fan.
  8. Asus Zenbook UX31A Daughterboard Replacement, Daughterboard: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use tweezers to detach the cable from the board by pulling them gently toward the bottom edge of the board.
  9. Asus Zenbook UX31A Daughterboard Replacement: paso 9, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 6 mm screw that secures the daughterboard.
  10. Asus Zenbook UX31A Daughterboard Replacement: paso 10, imagen 1 de 1
    • Remove by carefully lifting the board from the laptop.
Conclusión
Sherwin
Miembro Desde 03/22/22
209 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 238
