Saltar al contenido principal
Asus Zenbook UX303L Speaker Replacement
Qué necesitas
  1. Asus Zenbook UX303L Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Remove the eight 3mm screws using the T5 Torx Screwdriver.
    • Remove the 8mm screw using the T5 Torx Screwdriver.
  2. Asus Zenbook UX303L Speaker Replacement: paso 2, imagen 1 de 1
    • Carefully remove the back plate from the laptop and located the battery and speakers towards the top.
  3. Asus Zenbook UX303L Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the four 4mm screws using the Phillips #0 screwdriver.
    • Remove the single 6mm screw using the Phillips #0 screwdriver.
  4. Asus Zenbook UX303L Speaker Replacement: paso 4, imagen 1 de 1
    • Using your finger, gently lift upwards to remove the connection clip from the motherboard.
  5. Asus Zenbook UX303L Speaker Replacement: paso 5, imagen 1 de 1
    • Gently pull the speaker connection clip outwards to remove it.
  6. Asus Zenbook UX303L Speaker Replacement: paso 6, imagen 1 de 1
    • Carefully remove the speaker wires that are tucked underneath the tabs located at the edge of the laptop case.
    • Gently remove the battery from the laptop, the defective speakers should be glued with adhesive to the battery.
  7. Asus Zenbook UX303L Speaker Replacement: paso 7, imagen 1 de 1
    • Carefully peel away the defective speakers from the battery.
Conclusión
Una persona más ha completado esta guía.
Ryan Snow
Miembro Desde 04/01/19
202 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G6, Harley Spring 2019 Miembro de IUPUI, Team S1-G6, Harley Spring 2019
IUPUI-HARLEY-S19S1G6
3 Miembros
7 Guías creadas
Un comentario
Is the Asus UX303L same as U303L?
Michael Wolf - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 29
Todo El Tiempo: 1,795
