Saltar al contenido principal
Asus Zenbook UX303L Cooling Fan Replacement
Qué necesitas
  1. Asus Zenbook UX303L Cooling Fan Replacement, Cooling Fan: paso 1, imagen 1 de 1
    • Make sure the device is turned off and disconnected from the battery charger.
  2. Asus Zenbook UX303L Cooling Fan Replacement: paso 2, imagen 1 de 3 Asus Zenbook UX303L Cooling Fan Replacement: paso 2, imagen 2 de 3 Asus Zenbook UX303L Cooling Fan Replacement: paso 2, imagen 3 de 3
    • Remove the rubber pads closer to the air vents and remove the two screws using a P0 screwdriver.
    • Remove all the nine screws from the bottom of the device using a T5 screwdriver.
    • Carefully remove the bottom cover.
  3. Asus Zenbook UX303L Cooling Fan Replacement: paso 3, imagen 1 de 2 Asus Zenbook UX303L Cooling Fan Replacement: paso 3, imagen 2 de 2
    • Pull on the black flap to lift the LVDS cable next to the cooling fan.
  4. Asus Zenbook UX303L Cooling Fan Replacement: paso 4, imagen 1 de 3 Asus Zenbook UX303L Cooling Fan Replacement: paso 4, imagen 2 de 3 Asus Zenbook UX303L Cooling Fan Replacement: paso 4, imagen 3 de 3
    • Remove the three screws from the hinges using a PH-1 screwdriver.
    • Open the device at a 90 degree angle to free the hinges.
  5. Asus Zenbook UX303L Cooling Fan Replacement: paso 5, imagen 1 de 3 Asus Zenbook UX303L Cooling Fan Replacement: paso 5, imagen 2 de 3 Asus Zenbook UX303L Cooling Fan Replacement: paso 5, imagen 3 de 3
    • Remove the screws attached to the cooling fan with a PH-1 screwdriver.
    • Disconnect the wire attaching the cooling fan to the motherboard.
  6. Asus Zenbook UX303L Cooling Fan Replacement: paso 6, imagen 1 de 2 Asus Zenbook UX303L Cooling Fan Replacement: paso 6, imagen 2 de 2
    • Gently lift and slide the cooling fan out.
Conclusión
4 personas más completaron esta guía.
Equipo
3 comentarios
After the 6 step Would i then just remove the dust on the cooling fan and reassemble after that? or replace the fan as a whole
Sean Gerald Wong - Contestar
I wish you guys had included the part number for the cooling fan.
mhyson - Contestar
I think that it is important to recommend to remove the battery first, otherwise there is a risk of short...
Don't ask me how I know... :-(
Nmariotti - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 22
Todo El Tiempo: 6,170
