Saltar al contenido principal
Asus Zenbook UX21e Cooling System Replacement
Qué necesitas
  1. Asus Zenbook UX21e Cooling System Replacement, Battery: paso 1, imagen 1 de 3 Asus Zenbook UX21e Cooling System Replacement, Battery: paso 1, imagen 2 de 3 Asus Zenbook UX21e Cooling System Replacement, Battery: paso 1, imagen 3 de 3
    • Using a T4 Torx screwdriver, unscrew the ten screws lining the bottom cover. Then, proceed to remove the bottom cover by sliding it out parallel toward the back of the computer.
    • There are two length of screws. Eight screws are 3mm and two are 5mm. The two 5mm screws always go into the two center holes along the back edge.
  2. Asus Zenbook UX21e Cooling System Replacement: paso 2, imagen 1 de 3 Asus Zenbook UX21e Cooling System Replacement: paso 2, imagen 2 de 3 Asus Zenbook UX21e Cooling System Replacement: paso 2, imagen 3 de 3
    • Using an iFixit opening tool and your other hand, gently lift the connector up from the tape wrapped around the connector wires and pry the connector from the motherboard.
  3. Asus Zenbook UX21e Cooling System Replacement: paso 3, imagen 1 de 1
    • Remove the battery by unscrewing the five 3mm screws using a Phillips #1 screwdriver.
    • One at each corner and one in the center.
  4. Asus Zenbook UX21e Cooling System Replacement: paso 4, imagen 1 de 2 Asus Zenbook UX21e Cooling System Replacement: paso 4, imagen 2 de 2
    • Lift the battery directly up and remove it from the device.
  5. Asus Zenbook UX21e Cooling System Replacement, Cooling System: paso 5, imagen 1 de 3 Asus Zenbook UX21e Cooling System Replacement, Cooling System: paso 5, imagen 2 de 3 Asus Zenbook UX21e Cooling System Replacement, Cooling System: paso 5, imagen 3 de 3
    • Remove the plastic piece (labeled M3 10) sitting on top of the fan by lifting from one edge and peeling it over.
  6. Asus Zenbook UX21e Cooling System Replacement: paso 6, imagen 1 de 2 Asus Zenbook UX21e Cooling System Replacement: paso 6, imagen 2 de 2
    • Disconnect fan from motherboard by pulling the small white and blue connector from its socket.
  7. Asus Zenbook UX21e Cooling System Replacement: paso 7, imagen 1 de 2 Asus Zenbook UX21e Cooling System Replacement: paso 7, imagen 2 de 2
    • Remove the seven 3mm screws that hold the cooling system down using a Phillips #1 screwdriver.
    • Four are along the heat sink above the CPU, one is on the side of smaller heat sink to the left of the CPU heat sink. Two are along the edge of the fan.
    • Remove the cooling system from the device.
Conclusión
To reassemble your device, follow these instructions in reverse order. Make sure to clean the CPU with a clean and dry cloth and compressed air. You must also squeeze new thermal paste onto the CPU before reassembling.
Una persona más ha completado esta guía.
Zachary Eslick
Miembro Desde 04/23/18
756 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S22-G1, Maness Spring 2018 Miembro de Cal Poly, Team S22-G1, Maness Spring 2018
CPSU-MANESS-S18S22G1
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 1,082
