Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introducción
The Asus ZenWatch 2 comes equipped with two detachable leather straps. Straps are available in two sizes and new straps can be purchased in a variety of colors, patterns, and premium materials. Replacing the straps is a simple process found in the guide below.
  1. Locate the sliding knobs on the underside of the watch.
    • Locate the sliding knobs on the underside of the watch.
  2. Slide the knob inward.
    • Slide the knob inward.
  3. Pull up at an angle to detach the strap from the faceplate. Repeat for the other side as well.
    • Pull up at an angle to detach the strap from the faceplate.
    • Repeat for the other side as well.
Conclusión
3 personas más completaron esta guía.
Moriah
Miembro Desde 20/02/17
700 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S1-G1, Leahy Spring 2017 Miembro de USF Tampa, Team S1-G1, Leahy Spring 2017
USFT-LEAHY-S17S1G1
3 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 1,074
