Saltar al contenido principal
Asus ZenBook UX303U Battery Replacement
Qué necesitas
  1. Asus ZenBook UX303U Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the two round rubber feet at the hinge-edge of the laptop.
  2. Asus ZenBook UX303U Battery Replacement: paso 2, imagen 1 de 1
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
  3. Asus ZenBook UX303U Battery Replacement: paso 3, imagen 1 de 2 Asus ZenBook UX303U Battery Replacement: paso 3, imagen 2 de 2
    • Using a plastic opening tool pry the back panel off of the laptop.
  4. Asus ZenBook UX303U Battery Replacement, Battery: paso 4, imagen 1 de 2 Asus ZenBook UX303U Battery Replacement, Battery: paso 4, imagen 2 de 2
    • Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
  5. Asus ZenBook UX303U Battery Replacement: paso 5, imagen 1 de 2 Asus ZenBook UX303U Battery Replacement: paso 5, imagen 2 de 2
    • Remove all seven 2 mm Phillips #00 screws from the battery.
  6. Asus ZenBook UX303U Battery Replacement: paso 6, imagen 1 de 2 Asus ZenBook UX303U Battery Replacement: paso 6, imagen 2 de 2
    • Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
  7. Asus ZenBook UX303U Battery Replacement: paso 7, imagen 1 de 2 Asus ZenBook UX303U Battery Replacement: paso 7, imagen 2 de 2
    • Lift the battery connector straight up off its socket to disconnect it from the motherboard.
    • Do not pry on the socket itself or you risk damaging the motherboard.
  8. Asus ZenBook UX303U Battery Replacement: paso 8, imagen 1 de 2 Asus ZenBook UX303U Battery Replacement: paso 8, imagen 2 de 2
    • Lift the battery and speakers up and pull out to remove.
    • Check underneath the battery for the wire assembly connecting the touchpad to the motherboard. This connection may stick to the underside of the battery. Be careful not to damage it when removing the battery.
  9. Asus ZenBook UX303U Battery Replacement: paso 9, imagen 1 de 1
    • Remove the speakers from the old battery.
Conclusión
16 personas más completaron esta guía.
Dean Anderson
Miembro Desde 02/14/18
624 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S3-G5, Nance Spring 2018 Miembro de USF Tampa, Team S3-G5, Nance Spring 2018
USFT-NANCE-S18S3G5
3 Miembros
9 Guías creadas
11 comentarios
hello where I can buy a UX303U battery for asus?
jeannette dreifus - Contestar
hello! Where I can buy a UX303U battery for my Asus netbook?
thanks
There are two screws holding the back panel in place. They are located below the two rubber pads at the back of the pc. They must be removed in order to open the back panel.
Dave Man - Contestar
Just gone through this, but two problems surfaced. 1 it won’t connect to our usual WiFi router and can’t figure out why. Is it possible to damage the WiFi connectivity when removing battery? 2 there’s no indication of charge levels. It says 100% and doesn’t change. Thoughts?
Barny Harper - Contestar
Take all that back. Went back in and battery connector hadn’t clicked in far enough. Seems to be working fine now.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 21
Ultimos 30 días: 132
Todo El Tiempo: 30,487
