Saltar al contenido principal
Asus ZenBook Flip UX360C Solid State Drive Replacement
Qué necesitas
  1. Asus ZenBook Flip UX360C Solid State Drive Replacement, Solid State Drive: paso 1, imagen 1 de 1
    • Attach an ESD wristband to your wrist and clip the grounding clamp to a grounded metal object.
  2. Asus ZenBook Flip UX360C Solid State Drive Replacement: paso 2, imagen 1 de 1
    • Remove all eleven 5 mm Phillips #1 screws on the back cover.
  3. Asus ZenBook Flip UX360C Solid State Drive Replacement: paso 3, imagen 1 de 1
    • Use plastic opening tools to remove the keyboard panel.
  4. Asus ZenBook Flip UX360C Solid State Drive Replacement: paso 4, imagen 1 de 1
    • Use a plastic opening tool to disconnect the ZIF keyboard ribbon cable from the motherboard.
  5. Asus ZenBook Flip UX360C Solid State Drive Replacement: paso 5, imagen 1 de 1
    • Unscrew the 5 mm Phillips #1 retaining screw holding the SSD in place.
    • Carefully remove the SSD.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 51
Todo El Tiempo: 3,331
