Saltar al contenido principal
Este teardown está en en curso – Recarga periódicamente para ver los cambios más recientes!
Qué necesitas
Resumen del Video
  1. Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: paso 1, imagen 1 de 3 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: paso 1, imagen 2 de 3 Asus ZenBook 13 UX331U Teardown, Asus ZenBook 13 UX331U Teardown: paso 1, imagen 3 de 3
    • The back panel is removed.
    • The SSD is removed.
IT FIX
Miembro Desde 10/16/17
6,340 Reputación
74 Guías creadas
12 comentarios
Bonjour,
Je n' arrive pas a voir le disque dur de l' ordinateur. Est il accessible?
Peut il être changé ?
schauch - Contestar
You mean that you pc can’t see the hard drive? Even in bios?
IT FIX - Contestar
Boni can't see it on the video. I d like to buy one of these laptop and change the hard drive for a bigger one. Is it easy to do it?
schauch - Contestar
It’s very easy but it’s supports only M.2 SSDs
IT FIX - Contestar
Hi there,
I own this laptop, and the internal fan has started to make rattling-like noises, as well as suddenly stopping and starting after a period of watching videos and the like. I am wondering if this is due to dust clogging the CPU fan, and whether compressed air can be used to clean up. If it’s not due to dust clog, what else might be the problem?
Thanks.
Sai - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 46
Todo El Tiempo: 6,469
