Introducción
This guide will teach you how to replace the cooling fan prevent overheating on your Asus Zen AiO.
Qué necesitas
Use the plastic opening tool to pry off the black plastic strip at the bottom of the screen by wiggling the tool between the strip and the screen.
Run the opening tool slowly along the base of the screen, peeling the black strip back, until the opposite end of the screen is reached.
Place the computer on its back, facing up.
Wedge the plastic opening tool in between the screen and the bezel of the aluminum computer casing.
Move the tool along the entire edge of the screen with an up-and-down prying motion to loosen the screen from the casing. Do not lift the entire screen away from the computer yet.
Use a Phillips #0 screwdriver to remove the three (3) 4.8 mm screws from the fan unit.
Remove the cable connecting the fan to the motherboard by pulling the cable out of its socket.
