Saltar al contenido principal
Asus Z54C-JS31 WiFi Card Replacement
Qué necesitas
  1. Asus Z54C-JS31 WiFi Card Replacement, Battery: paso 1, imagen 1 de 3 Asus Z54C-JS31 WiFi Card Replacement, Battery: paso 1, imagen 2 de 3 Asus Z54C-JS31 WiFi Card Replacement, Battery: paso 1, imagen 3 de 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: paso 2, imagen 1 de 2 Asus Z54C-JS31 WiFi Card Replacement, HDD/RAM Cover Panel: paso 2, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Asus Z54C-JS31 WiFi Card Replacement: paso 3, imagen 1 de 2 Asus Z54C-JS31 WiFi Card Replacement: paso 3, imagen 2 de 2
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  4. Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: paso 4, imagen 1 de 3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: paso 4, imagen 2 de 3 Asus Z54C-JS31 WiFi Card Replacement, WiFi Card: paso 4, imagen 3 de 3
    • Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
  5. Asus Z54C-JS31 WiFi Card Replacement: paso 5, imagen 1 de 3 Asus Z54C-JS31 WiFi Card Replacement: paso 5, imagen 2 de 3 Asus Z54C-JS31 WiFi Card Replacement: paso 5, imagen 3 de 3
    • Remove the 3mm screw from the top right corner of the WiFi card using a Phillips #0 screwdriver.
    • The WiFi card will pop up. Grasp it and pull it out of its slot.
Conclusión
Mark DeSimone
Miembro Desde 10/19/17
801 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 1,427
