Saltar al contenido principal
Asus Z54C-JS31 Motherboard Replacement
Qué necesitas
  1. Asus Z54C-JS31 Motherboard Replacement, Battery: paso 1, imagen 1 de 3 Asus Z54C-JS31 Motherboard Replacement, Battery: paso 1, imagen 2 de 3 Asus Z54C-JS31 Motherboard Replacement, Battery: paso 1, imagen 3 de 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Motherboard Replacement, HDD/RAM Cover Panel: paso 2, imagen 1 de 2 Asus Z54C-JS31 Motherboard Replacement, HDD/RAM Cover Panel: paso 2, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the two 9mm screws from the HDD/RAM cover panel.
  3. Asus Z54C-JS31 Motherboard Replacement: paso 3, imagen 1 de 2 Asus Z54C-JS31 Motherboard Replacement: paso 3, imagen 2 de 2
    • Slide the back panel off by placing a hand on each corner and pulling the panel towards you.
  4. Asus Z54C-JS31 Motherboard Replacement, Hard Drive: paso 4, imagen 1 de 2 Asus Z54C-JS31 Motherboard Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Remove the four 9mm screws holding the hard drive in place.
  5. Asus Z54C-JS31 Motherboard Replacement: paso 5, imagen 1 de 3 Asus Z54C-JS31 Motherboard Replacement: paso 5, imagen 2 de 3 Asus Z54C-JS31 Motherboard Replacement: paso 5, imagen 3 de 3
    • Slide the hard drive to the left to disconnect it.
    • Then pull on the black tab to lift the hard drive out of the laptop.
  6. Asus Z54C-JS31 Motherboard Replacement, WiFi Card: paso 6, imagen 1 de 3 Asus Z54C-JS31 Motherboard Replacement, WiFi Card: paso 6, imagen 2 de 3 Asus Z54C-JS31 Motherboard Replacement, WiFi Card: paso 6, imagen 3 de 3
    • Disconnect both the black and white coaxial connectors from the WiFi card by pulling up on the gold colored piece.
  7. Asus Z54C-JS31 Motherboard Replacement: paso 7, imagen 1 de 3 Asus Z54C-JS31 Motherboard Replacement: paso 7, imagen 2 de 3 Asus Z54C-JS31 Motherboard Replacement: paso 7, imagen 3 de 3
    • Remove the 3mm screw from the top right corner of the WiFi card using a Phillips #0 screwdriver.
    • The WiFi card will pop up. Grasp it and pull it out of its slot.
  8. Asus Z54C-JS31 Motherboard Replacement, Keyboard: paso 8, imagen 1 de 2 Asus Z54C-JS31 Motherboard Replacement, Keyboard: paso 8, imagen 2 de 2
    • Turn the laptop to its normal position and open the display to show the keyboard.
    • Gently push back the five tabs holding the keyboard down using the plastic opening tool.
  9. Asus Z54C-JS31 Motherboard Replacement: paso 9, imagen 1 de 3 Asus Z54C-JS31 Motherboard Replacement: paso 9, imagen 2 de 3 Asus Z54C-JS31 Motherboard Replacement: paso 9, imagen 3 de 3
    • Once the keyboard is free, disconnect the ribbon cable from the zero insertion force (ZIF) connector by flipping up the locking flap and pulling the cable out.
  10. Asus Z54C-JS31 Motherboard Replacement, Optical Disc Drive: paso 10, imagen 1 de 3 Asus Z54C-JS31 Motherboard Replacement, Optical Disc Drive: paso 10, imagen 2 de 3 Asus Z54C-JS31 Motherboard Replacement, Optical Disc Drive: paso 10, imagen 3 de 3
    • Remove the 3mm screw with a Phillips #000 screwdriver.
    • Slide out the optical disc drive by pulling it away from the laptop.
  11. Asus Z54C-JS31 Motherboard Replacement, Motherboard: paso 11, imagen 1 de 3 Asus Z54C-JS31 Motherboard Replacement, Motherboard: paso 11, imagen 2 de 3 Asus Z54C-JS31 Motherboard Replacement, Motherboard: paso 11, imagen 3 de 3
    • Turn the laptop over so that the back side is facing up.
    • Remove eight 9mm screws from the back of the laptop.
    • Remove two 6mm screws near the battery.
    • Remove two 3mm screws from the optical drive slot.
  12. Asus Z54C-JS31 Motherboard Replacement: paso 12, imagen 1 de 2 Asus Z54C-JS31 Motherboard Replacement: paso 12, imagen 2 de 2
    • Disconnect the two ribbons cables from the zero insertion force connectors by flipping up the small locking flap and pulling them gently out of the connectors.
  13. Asus Z54C-JS31 Motherboard Replacement: paso 13, imagen 1 de 2 Asus Z54C-JS31 Motherboard Replacement: paso 13, imagen 2 de 2
    • Use the plastic opening tool to pop off the plastic layer by sticking it in between the two parts and sliding it around the whole laptop.
    • Lift off the top plastic layer.
  14. Asus Z54C-JS31 Motherboard Replacement: paso 14, imagen 1 de 2 Asus Z54C-JS31 Motherboard Replacement: paso 14, imagen 2 de 2
    • Disconnect the two ribbon cables from the no-fuss ribbon cable connectors attached to the motherboard by pulling the cable straight out of the connector.
    • Disconnect the ribbon cable from the zero insertion force connector by flipping up the locking flap and pulling the cable out.
  15. Asus Z54C-JS31 Motherboard Replacement: paso 15, imagen 1 de 3 Asus Z54C-JS31 Motherboard Replacement: paso 15, imagen 2 de 3 Asus Z54C-JS31 Motherboard Replacement: paso 15, imagen 3 de 3
    • Remove the two 5mm screws holding the motherboard and fan in place.
    • Lift out the motherboard and fan.
Conclusión
Mark DeSimone
Miembro Desde 10/19/17
801 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 427
