Saltar al contenido principal
Asus Z54C-JS31 Display Replacement
Qué necesitas
  1. Asus Z54C-JS31 Display Replacement, Battery: paso 1, imagen 1 de 3 Asus Z54C-JS31 Display Replacement, Battery: paso 1, imagen 2 de 3 Asus Z54C-JS31 Display Replacement, Battery: paso 1, imagen 3 de 3
    • Turn the laptop upside down so that the underside is facing up and locate the two switches that are on each side of the battery.
    • Slide the switch on the top right corner to the right.
    • Slide and hold the switch on the top left corner to the left and carefully remove the battery.
  2. Asus Z54C-JS31 Display Replacement, Display: paso 2, imagen 1 de 3 Asus Z54C-JS31 Display Replacement, Display: paso 2, imagen 2 de 3 Asus Z54C-JS31 Display Replacement, Display: paso 2, imagen 3 de 3
    • Open up the laptop and locate the two circular stickers at the bottom corners of the display.
    • Use a pair of tweezers to remove the two black stickers covering the screws.
    • Using a Philips #000 screwdriver, remove the two 9mm screws.
  3. Asus Z54C-JS31 Display Replacement: paso 3, imagen 1 de 2 Asus Z54C-JS31 Display Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to pop off the plastic border around the display.
  4. Asus Z54C-JS31 Display Replacement: paso 4, imagen 1 de 3 Asus Z54C-JS31 Display Replacement: paso 4, imagen 2 de 3 Asus Z54C-JS31 Display Replacement: paso 4, imagen 3 de 3
    • Remove the two 9mm screws from the top corners of the display with a Phillips #000 screwdriver.
    • Carefully lift the display out and place the screen face down on the keyboard.
  5. Asus Z54C-JS31 Display Replacement: paso 5, imagen 1 de 1
    • Disconnect the display cable connector attached to the display.
Conclusión
Mark DeSimone
Miembro Desde 10/19/17
801 Reputación
8 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 149
